E30 or E36 aluminum shift arm?
  • DTFE30
    • Feb 2011
    • 471
    Noob here again. I have the early style getrag with the steel plate that holds the shift rod. Should I use the E30 aluminum arm or the E36 with my S50 and Zf320? And from there I would order the appropriate mounting bushing for the back end.
  • Irvingm1991
    • Oct 2014
    • 15
    What did you end up using im going through the same issue right now
    • BlackSpeed66
      • Apr 2008
      • 626
      Just went through this with my s52/ZF320 swap on my car. The stock e30 arm is a bit too short, and the one from the ZF320 puts it off-center of the hole in the trans tunnel. I wound up using an early e46 shift carrier. It does have to be shortened but it centers the shifter better. Shown here with part of the the UUC SSK
      -Geno
      '87 325is (s52'd)
      '95 525iT
      '95 Jaguar XJR-6
      '02 Range Rover 4.6 HSE
      '98 Disco 1
