M42 Wiring harness To E34 M50 Harness
  • KangamangusDriver
    • Aug 2005
    • 1870
    Hello all! I am new to the site and find it very informative. kudos to everybody!!
    I am currently swapping a M50 from a 95 525I into my 1991 318IS.
    Are there any wiring differences I should be aware of when wiring the harnesses together. So far I have been using AKG motorsports wiring diagram. The M50 swap thread has been very informative. I did not find any light on this particular swap and was curious to see if anyone had any insight or ideas.
    Thank you!
  • Jordan
    • 12913
    AKG's diagrams are horrid. Nothing there is correct.
    Buy one of Treehouse Racings WHAD's and be done with it.
    edit: Hello Adam.
    https://mtechniqueabs.com/
    • e30Matt
      • 5077
      I second Jordan. We used AKG's diagram just as a base, and the only wire that was right (as far as we could tell) is the starter wire. I'm flipping through the ETM and Bentley right now, making an accurate wiring chart.
      • Xmarksthespot21
        • Jun 2004
        • 285
        Let me take a look at the chart whenever you finish. I dont think mine is wired completely right.
        • Jason89i
          • Sep 2004
          • 875
          drop me a line too. i have done 2 of them and have finally figured out the o2 / fuel pump relay wiring......correctly. jason
          • Ferret
            • May 2005
            • 101
            I'm also I am swapping a M50 from a 95 525I into my E30 ('85 320i). The differences I found between the E36 engine plug and the E34 engine plug:
            1. The oil level sensor goes to pins 1 and 2 instead of 10 and 16.
            2. The Oxigen sensor relay gets power from the main relay, not from pin 22.
            The other wires seem to need to be connected to the same pins in the E36 and E34 engine plugs.
            Avner.
