M52 vacuum hose
  • bostonbmw
    • Nov 2004
    • 429
    M52 vacuum hose
    Perhaps someone willl know here.What does #19 connect to ? I removed my intake manifold and I can not figure out where it goes.
    PS this is on my e36 328
  • 328ijunkie
    • May 2007
    • 3961
    exhaust flap valve. Runs through glovebox.
    Check Us out on Facebook
    Full Product Line Tuning
    • bostonbmw
      • Nov 2004
      • 429
      I got the Exhaust flap connected to the #1 location via the Tee. There is another small vacuum port near the #1 location, does that get capped off?
      • luckysnafu
        • Jun 2008
        • 262
        Replace the T #2 with an elbow and connect #1 to the underside of the manifold. This eliminates #19 and the exhaust flap valve.
        M/S52 Wiring Diagrams
        Z3M S52 to late model 325i wiring diagram
        M52 to 318is wiring diagram
