Oil leak at Tranny bell housing
  • graphikg
    • Jan 2008
    • 1614
    I searched...
    I have this leak at the bell housing. It looks like tranny oil but I am not sure; its dark oil. I have not lifted the car to check but I did replace the rear crank seal when I replaced the oil pan gasket. any idea?
  • zxert
    • Jan 2011
    • 444
    Most tranny fluid is clearish. Its probably oil. Clean up the area as best as you can to pin it down. I'm guessing rear crank seal.
    Originally posted by StewStewIloveyouyou
    hahahahahahahahahahahahahahahahahah f--- this community its like am making my life with you guys
    And am making my life with you guy too. ;)
    • samiam3356
      • Jul 2009
      • 1901
      rear main
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • graphikg
        • Jan 2008
        • 1614
        DAMN!!! I really dont want to take that damn tranny out again. What a B**** of a job it is. And I already did the rear main seal - why would it be leaking?
        • cabin
          • Dec 2006
          • 552
          Transmission input shaft seal.
          Not all tranny fluid is clear...could be red if using ATF.
          -Justin
          Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
          • graphikg
            • Jan 2008
            • 1614
            How can I test which oil it is? Honestly... when I let the car idle in place, I find both clear oil and sometimes and dirty oil. (?????)
            • e46s54dr
              • May 2008
              • 1059
              Easiest way is prolly to smell it. It may sound stupid but they have distinct odors to them.
              • Philo
                Ich esse kleine Kinder
                • 3334
                Answer: Improper installment. That is usually the case when putting a new seal in. I always take my time when installing. It's imperative to make sure the rubber ring is even and laying flat around the entire rim.
                -tim
                Originally posted by Jordan
                I like the stance
                • mr.vang
                  • 4371
                  you taste it. tranny oil will taste like chicken
                  • graphikg
                    • Jan 2008
                    • 1614
                    I was thinking improper installment; but either this just started happening after no leaks for about 40-50 miles or so, or I just started noticing it. However, I have been driving it close distances and have noticed that it is leaking less and less. Now it is to the point where it drops maybe 10-15 drops in a couple hours when earlier in the day is was a drop every 5 seconds or so. ?????
