Quick question...
  • MeanM50
    • Apr 2008
    • 116
    Quick question...
    What BMW header gaskets am I supposed to use with OBDII headers on an OBDI M50?
  • lolcantturn
    • 4588
    the same ones. doesn't matter
    HOWEVER, you're going to need E92 EGR delete plate in order to cover the hole from the EGR on OBDII headers. This is the easiest, simpliest way to do it besides bringing your headers to an exhaust shop to cover the hole up.
    Originally posted by TSI
    OEM+
    • MeanM50
      • Apr 2008
      • 116
      I have the headers all closed up. Welded the recirc. and obtained bungs for the O2 holes. When you say 'the same ones' do you mean the gaskets from an M50? Or the gaskets for the M52 that the headers came off?
      Sorry...just tryin' to do this once.
      • EduardoGomez
        • Feb 2011
        • 48
        you must use OBD2 gaskets there, because OBD1 gaskets will not seal that EGR channel
        • MeanM50
          • Apr 2008
          • 116
          Thanks Eduardo! That was exactly what I was looking for.
