Finishing up my M50 swap need some help!!!
  • 1991318is
    • Nov 2004
    • 54
    My engine is installed finally after a year of patience and buying parts, it started and everything seem's normal. Whe have one little problem that whe did not figure out yet. I have a thermostat for the throttle body that whe dont know where it goes. My engine is a 1994 325is. Whe checked everywhere on the engine. Where thinking that this was used on the original air box wich i dont have since i'm using a pflow. It's connected with both pipes and hagging in the engine bay. I would like to have someone's opinion that had this experience.
  • Brew
    • 3060
    Yeah, thats the air intake temperature sensor. It mounts to the airbox. I just have mine zip-tied undereath my cone filter.
    '91 318is
    • Jordan
      • 12916
      Zip tied lol. Just buypass that stupid thing.
      https://mtechniqueabs.com/
      • Brew
        • 3060
        There's nothing wrong with zip ties. :oops:
        It gets pretty cold up here in the winter so I kept the thing operational.
        '91 318is
        • 1991318is
          • Nov 2004
          • 54
          Thanks for clearing this out for me. Very apreciated!!! :D
          • KangamangusDriver
            • Aug 2005
            • 1870
            I bypassed the one on mine. Hopefully wont effect the heating since it gets cold up here in NH. However that is what winter beaters are for
            • f u z z
              • 1600
              I also had mine ziptied. but it looked stupid because.. so on the back of my cone filter i drilled a hole in the rubber part and stuck it in there (on the bottom out of sight) and it stays put. my car ran actualy ran a little smoother..? or am i on drugs
              • pussy
                • Aug 2005
                • 34
                in my country.. we bypass it.. weather here very hot.. car runs much better.. :D
                • f u z z
                  • 1600
                  when we say "bypass"... are we just using a U shaped pipe to connect the two hoses going to it?
                  • KangamangusDriver
                    • Aug 2005
                    • 1870
                    yes, that is what I did
                    • f u z z
                      • 1600
                      awsome.
                      problem solved. No more leak.
