My S50 swap has been done for about a month or so now and it keeps giving me "ghost" issues. The first problem I was having was the speedometer A signal fail. Swapped a few clusters and finally found the right combo and learned that if I drove the car easy for 30mins-1hr that fail wouldn't pop up anymore. Next I started getting a lambda control pos. 1 (O2 sensor). The car would sputter and buck and run like ass until I went WOT and then it seemed like it cleared it up until I turned the car off and let it sit for ~30mins. I swapped the o2 sensor with a known good one and it ran perfectly for a day and I drove her the next morning and the same sputtering and spitting popped up. All while doing this whenever the CEL is on the power drops off around 5500rpm and will completely stop and not pull anymore at around 6500. My redline is set at 7250. I've reset the ECU countless times and she will run good for about 10mins or until I give it one good pull. Another thing she is doing is if the CEL is off and been running fine for a few mins the light will come on and if I give it a small rev will go back off. If anyone has had the same issues and knows what my fix is PLEASE enlighten me bc I am boggled out of my mind.
Ghost problems, NEED HELP
at one point in time you reversed the polarity on the harness or on the battery, burning up the MAF sensor. Put another MAF sensor and see if that is the problem. -
Originally posted by Roysneon$5 shipped?Originally posted by MarkDYou are a strange dude, I'n not answering any more posts from you.Comment
