Car: 1991 318i
Engine: 93 m50tu
DME: 413 Red Lable
Engine will start and idle normal, as soon as you touch the gas it starts to break up and wants to die. Got dtc codes for MAF, and TPS. Changed MAF, TPS, plugs and coils. Couple questions. Does the 318 4 cylinder fuel pump, pump enough gas for the 6? I'm currently draining the gas tank incase the gas is bad (car sat for a year with less then a 1/4 tank. I took a video of it running so you guys can hear it. Let me know anything else i should check.
Engine: 93 m50tu
DME: 413 Red Lable
