The Car: 1991 318i
engine: 1992 NV m50 from an e36
Symptoms: If/when the car starts, the idle shoots straight up then dies out, if the car is shut off, it won't start again.
What I have checked/replaced:
Crank/cam sensors - good
Spark plugs/coil packs - all good
Coolant temp sensor plugged into the harness correctly - good
I tried to check my fuel pressure last night, unsuccessfully. The gauge I bought from autozone was made for a schrader valve, which to my knowledge (now), this car does not have. I'm working on getting the right sized t-fitting and some extra fuel line to check the pressure, unless you fine gentlemen have a more efficient/easier solution for this.
So, I believe this narrows it down to a few things -
I THINK that it could be one of the following -
- bad fuel pump - need to be able to check pressure first though..
- bad fuel pressure regulator - although, the plugs were NOT that wet with fuel after cranking
- bad/clogged injectors? - I was told they were good and tested though, bought them from a r3v member
- bad MAF - I fried a ground going to the maf a while back that might have killed the maf itself, however, my issue still persists with the maf unplugged
I dunno r3v, what does this issue sound like to you. Or have any of you experienced things similar to this in the past?
