Hey guys,
I've got a 92 m50nv in my 89 325is. I have no fuel or spark. If I jump the fuel pump relay I can get the pump to run.
Anyways, I was going through the plugs on the fuse box side of my wiring harness adapter and probed pin number 21 which is supposed to control power from the ignition switch to the DME. It showed 0 volts, but fuse 9 (ignition electronics) popped. I swapped out the fuse a few more times and had the same result. This makes me think that there's a short or something. I feel like if I can isolate the problem I can finally fix my problem. Let me know if you have an insight. Thanks!! 8-)
