Best shim or washer to use for motor mount on 24v for exhaust to clear?
  • ill4noreason
    • 2710
    So I am running m52 Obd2 headers with a custom exhaust past the down pipe. I am rubbing on the swaybar what is the best shim or washer to use to get one side of the engine up a little? Thanks
    My Multi car part out. Need a part? Pm me...
    http://www.r3vlimited.com/board/showthread.php?t=193051
    Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
    http://www.r3vlimited.com/board/showthread.php?t=215044
    Have you done business with me? If so leave me feedback here...
    http://www.r3vlimited.com/board/showthread.php?t=188307
  • Matt-B
    The Waffler
    • 3856
    you can space the subframe a bit, someone here sells the spacers, or heat exhaust pipe, and "bend" or "push" it in
    • Wishno87
      • 6025
      Someone makes a spacer to move the sway bar down a bit..
      • 7pilot
        • 475
        Agreed. Shim the swaybar down.
        Don't raise the mass of the engine, especially if you are going to really drive the car.
        m
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          I just used a stack of fender washers.
