What gearbox+diff combo would produce this....
  • wakdog
    • 223
    So I just took a M50 swapped 325i for a test drive and was a little stumped as to what gearbox/diff setup the car is running...
    5th gear 110kmh (68mph) and its sitting on 3500rpm.......
    Diff back case says S3.73 but the owner has told me it has a 3.91 ratio in it....
    As far as I can see the only way this can be right is if the car has a 3.91 diff and a 1:1 5th gear which is stupidly close for something I would want to daily drive (my race car has an M20 with G260 + 4.1 LSD and i find that way to high revving to drive on the motorway...)
    90 318i M62B44 OBD1
    02 530i Touring (Airlift 3P)
  • nrubenstein
    • 3148
    All E3) transmissions had a 1:1 5th.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • DTM190
      • Nov 2008
      • 1107
      In whos dreams?
      Originally posted by der affe
      first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
      if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
      • DTM190
        • Nov 2008
        • 1107
        What RPM does your race car sit at doing 110? I have a calculator in excel somewhere, will dig it up
        • wakdog
          • 223
          Cant really remember the racecar rpm, its been off the road having 2.7L stroker built since early this year but im guessing about 3300rpm ish
          90 318i M62B44 OBD1
          • DTM190
            • Nov 2008
            • 1107
            Have a play with calc http://www.csgnetwork.com/rpmcalc.html
            Sounds lie 4.27 if it had the non existant 0.81 5th box
            Or 3.46 if it did have a 1:1 5th box
            • wakdog
              • 223
              68mph
              25inch tire (car is running 205/55/16 tires)
              3.73:1 Final drive
              1:1 5th
              = 3408rpm
              68mph
              3.91:1 Final drive
              1:1 5th
              = 3573rpm
              hmmm so maybe the guy is wrong and it does have a 3.73 diff, cause its definitely closer to 3400rpm @ 110 than it is 3600....
              Wonder how hard it would be to get a 3.25:1 LSD in AUS or if someone would wan to swap one for this 3.73....
              ::: The M50 car feels similar to my racecar when it had a 4.45:1 (that was fun... welded 4.45 hehehe)
              90 318i M62B44 OBD1
              • DTM190
                • Nov 2008
                • 1107
                I worked on tyre size close to factory.
                Reason being BMW would use the original tyre size to calibrate the speedo.
                The larger OD tyres are only going to change actual speed, not alter the speedo to rpm equation unless you were using a GPS to measure speed?
                • dreamchasin
                  • 3892
                  I run NVm50>G260>4.10 LSD and I love it :D
                  90 325is alpine2 m50b25 becoming a dorifto car.
                  • Wanganstyle
                    • 2828
                    All 5 speed manual gearboxes Paired OEM by BMW to 24v engines had 1:1 5th gear; basically the 4th of any e30 original 5 speed transmission.
                    3.47, 3.38, 3.25, 3.23, 3.15, 3.07, 2.93 are all popular ratios to run with a 1:1 non-overdrive 5th gear in an e30 with 24v swap
                    3.73+ 1:1 5th gear 5mt is pretty insane, not a daily driver option if fuel costs are of concern.
                    6 speed manual with 3.73 is good though, e46M3 with getrag 6mt has a 3.62 final drive standard.
                    • dreamchasin
                      • 3892
                      I don't get bad gas mileage with my setup I have above. Not the greatest and I beat on my e30. Maybe Luke 18-20.
                      • Wanganstyle
                        • 2828
                        non vanos M50 was paired OEM by BMW with a 4.10 in some e34's. its not terrible as the NV lacks torque on bottom end to pull the 3800lb sled around; this was great for my e34it.
                        • lbreevesii
                          • Aug 2009
                          • 412
                          big calculator/comparison tool here:
                          This is the official website for the Georgia Fiero Club. We specialize in helping other people with Fieros, organizing Fiero-related events, etc.
                          I don't always wreck cars, but when I do I wreck them into trees.
                          91' 318is S50 swap - The Black Widow
                          • wakdog
                            • 223
                            I ended up buying the car, got it on the hoist and it is a 3.91 crown/pinion, so im going to just swap it out for a 3.15 I pulled from a scrap eta
                            90 318i M62B44 OBD1
                            • DTM190
                              • Nov 2008
                              • 1107
                              What gearbox does it have, that was the missing link lol.
                              Pics? Where in aus?
