Solid Lifter Questions
  • Addissimo
    • Mar 2004
    • 1820
    So I'm looking at building a new engine, with a supercharger, or getting a euro engine, lowering the compression ratio, and supercharging. I really like the idea of the euro engine because of the solid lifters = High revs. I like high revs.
    VAC has solid lifter conversion kits blah blah blah. I'm wondering what can be achieved with a ballanced m52 aluminum block, solid lifters, and custom cams/mild head work. Am I looking at 8k redline, 8.5k? I obviously need double valve springs, are the performance ones that VAC sells worth the grand, or would the double valve springs from a non-vanos engine suffice?
    I realize it'd be expensive to go this route, but if I go with the m52, I can use a stand alone EFI system, and wouldnt have to worry about ews, expensive euro parts like ignition coils etc...
    Thanks-
    Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
  • DesertBMW
    • Aug 2011
    • 1043
    Ok. 9 years later we still don't understand your question
