M50 conversion - The Euro Depot
  • h1psi
    • Aug 2005
    • 1
    Not sure if anyone has seen this... http://www.theeurodepot.com/e30m50.html
    I plan on swapping an M50+e36 5speed into my 88 325is and want to go the easiest route possible.
    Using info. from this link as well as a Treehouse racing M50 conversion harness seems like the easiest, but am I missing anything??
  • Addissimo
    • Mar 2004
    • 1820
    Everything you could ever want to know is right here:
    -Addis
    PS Stick with the tranny from your current car. SERIOUSLY. Its more work, but the results are more enjoyable.
    -Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • KangamangusDriver
      • Aug 2005
      • 1870
      It is a lot of work and time. Plan on having a back up transpo, things never go as planned with this swap. I thought I could of had it done it two weeks, guess again. A month later I'm finally finishing up. The Euro Depot is good and reliable. I know all those guys personally.
      • sushipower
        • Aug 2005
        • 156
        You might want to check out Ziionsvile Autosport too. They sell kits from engine mounting, electrical, modified brake boosters...
        They also have a disk that documented every step.
        Good Luck! Im trying to do a S52 swap into a 89 e30.
