This morning my starter didnt go off at all. I jiggled my C101 connector thing that I did a shabby job of doing and the starter worked right away. Today when I went to work and turned my car off and went to turn it back on, there like a second or so delay when I turn the key and then the starter works. What's the deal? I know my wiring is shitty, I also grounded the unloader relay before the starter so that my windows could work, but I never had this problem.
Starter acting kinda funny
Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Tags: None -
Sounds like the answer is in your original post. Suspect wiring
Originally posted by Roysneon$5 shipped?Originally posted by MarkDYou are a strange dude, I'n not answering any more posts from you.Comment
Open the wiring and see if any of your connections came loose. Hope it's a simple fix!Comment
opened up my harness and everything seemed sloppy but still together. It seemed that the connector from the starter to the power block was loose, tightened it up and it seems to have solved it!Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Goods news! Congrats
