I've had 4 E30s, and I have loved the fun handling of all of them. I've had 2 E36 M3s and I loved the motors. I had an S52 M Coupe, and it was juuuust riiiiight... except it had too few doors, and too many miles.
I wanted a 4 door M Coupe with a few less pounds, and less "irreplaceable" sheet metal so I could actually park it and not worry. Trailing throttle oversteer, decent torque, and enough horsepower to get into trouble. As we all know, there is only one way to do that...
...and thus was borne the "M Crap!" The handling and motor magic of an M coupe, but at 1/10th the budget. Hopefully. Maybe. Probably not.
In any case, this will be my swap thread, with pics, details, and questions for you experienced swappers, if and when I run into issues. I've read the threads, the wiki, and this forum for months as a lurker... I think I am ready. I hope I am ready...
The high-level plan:
From the E30 - Chassis: 1991 325i sedan - 225K miles
Not from the E30
Motor has 120K, but known maintenance history for the last 30K miles. It was tracked, and didn't have an oil pan baffle, so I plan to change the rod bearings and bolts, since I have to have the pan off anyhow. I am going to leave the rest of the motor as is, and slam it in.
Phase one begins today:
I need to put all the accessories on, clean 'er up, and get the bearings checked and measured and ordered up.
I'll keep the thread updated over time as I get things done, to help keep me motivated, and to maybe be a reference for others down the line.
The car, as it sits now:
Process pics to follow
- Stock wiring harness, for the connector
- Stock late model radiator and expansion tank
- Getrag 260 from same, with White325is brace
- 3.73 LSD (already installed)
- Stock Booster (will relocate to clear manifold)
Not from the E30
- S50b30 - US
- 413 DME
- Vanos M50 harness
- e34 pan and tube and dipstick etc
- S52 exhaust manifolds, welded ports
