To make a short story long,
M50 swap is all but done. I pulled the fuel pump relay and plugs to crank the engine a bit to build oil pressure. The engine cranks about quarter revolution then it stops turning over. Get the breaker bar on the crank pulley and it's hard to rotate the motor. So I step back, pop the top on a fresh beer and fire up a fag to think a minute. Bam it hits me. The m20 flywheel could be rubbing the oil pan even though I ground down the high spots when fitting the flywheel. I crawl under the car and take a peep in the inspection holes and can see about a quarter inch of rubbing on the back of the flywheel. :hitler:
O.k. So I know the right answer is do the deed and pull the trans back out clearance it properly but damn it that's a bitch job at this point. Anybody have a tricky solution for me or just fight the trans out?
Thanks for all the wealth of knowledge on the r3v. I acquired the parts and installed this on my own without having to post a single ridiculous question that had not already been answered here a million times before.
