So once upon a time I was driving my swap car around and the temp gauge just went dead while I was driving, after this happened I got terrible gas mileage. Im talking like <5mpg. So I replaced the sensor and sender, nothing. My current was looking real bad and I had a feeling that was the issue so I swapped in a new one, but It seemed a tad different. I hooked it up and everything was a go except I wasnt getting fuel. Seems as if its not grounding (had this issue last time I pulled my motor and reinstalled to do the oil pan)
So heres my question, which are hots and which are grounds
Big red wire that goes that has one lead to the started and one that was labeled from PO as fuse box, guessing e34's used this and I dont need it.
This really confuses me, the big black wire that comes from connector at the battery tray, that goes to the starter right? Becuase the last mentioned cable I have going there too. And there is a wire that goes between the started and alternator thats hot to right?
Then there the cable that comes from the fuse box to the battery tray and splits off into 2 seperate connectors.
I think thats it, that you so so so so much to who ever takes the time to help me out, I havent driven my e30 in to long =[
The 2 wires that come out of the diagnostic connecter wire on passenger side
