Car stalls and doesn't want to start.
  • trackjunkie21
    • Jan 2010
    • 3962
    Well the car is having a weird problem, occasionally it just stalls out no matter the circumstances and does not want to start back up. At times I can here the pump turning on and it seems as if it's getting no spark, but most of the time it just cuts everything all together. I wiggle the fusebox a bit and all of a sudden all the relays click and the car starts. This is very weird since I already replaced the damn fusebox once and that was a huge PITA. All main relays are brand new and I'm starting to get very frustrated with this because I seem to be going nowhere fast. Any help?
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
  • samiam3356
    • Jul 2009
    • 1901
    Sounds like a loose connection. Had this issue when I forgot to tighten down the ground on my battery. Took a mintute to figure out because I was expecting something harder to figure out.
    Originally posted by Roysneon
    $5 shipped?
    Originally posted by MarkD
    You are a strange dude, I'n not answering any more posts from you.
    • trackjunkie21
      • Jan 2010
      • 3962
      Seems logical, but in the fusebox can be causing me to lose power for spark and fuel? I know I'm getting power to the fuel pump.
      • lolcantturn
        • 4588
        I guarantee it's something simple.
        Wiggling the fusebox means you could be tugging a bit on the fusebox 12V wire that runs to the hot power block in the engine bay, which could be enough to wiggle a loose connection to the DME. Check the powerblock. I had a similar problem where my starter didn't work and i kind of wiggled the fuse box and then it worked, but when i wiggled the fuse box it tugged on the fusebox 12V wire which tugged just enough on the powerblock to give power back to my starter.
        Originally posted by TSI
        OEM+
        • trackjunkie21
          • Jan 2010
          • 3962
          checked, powerblock is good and secure.
          • DaveSmed
            • Apr 2007
            • 1406
            Originally posted by trackjunkie21
            ... but most of the time it just cuts everything all together....
            When it does this, does it affect things inside the car as well? If so check that the allen bolt under K4 and K8 is tight.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • jrdeamicis
              • Nov 2008
              • 956
              Have you tried just cleaning the contacts on the relays. Measure for 12V @ PIN 30 OR PIN 86 on the relays.
              Past Car : E30 S50 6 Speed 5 Lug 3.73
              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
              ___________________________________________
              BNB Designs
              Engine Swaps, Fabrication, Innovation, General Repair
              Richmond CA
              Julian 848-248-8029
              • trackjunkie21
                • Jan 2010
                • 3962
                This does not happen, although I did check the allen bolt and it was nice and snug.
                Will try that when it happens again. Car is running fine now but probably not for long.
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  update: car died yesterday(wish I took a video) when I tried cranking, the CEL light would flash. Then I pulled the hod release and it started, wtf is this shit.
                  • scottinAZ
                    • Dec 2009
                    • 1312
                    check your relays. Mine did the same freaking thing until I replaced the three relays attached to the harness. finicky bastards they are
                    I saved 15% on my Bimmer parts by switching to ...
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      These are all brand new relays, bought last year, that's the funny part
                      • scottinAZ
                        • Dec 2009
                        • 1312
                        check the connectors for loose/bent contacts then. If the problem persists, swap in your old relays, new ones should be good to go, but it isnt unheard of for them to fail. Had this problem on my M20, swapped relays, good to go, did M50 swap, and got the old relay back in the mix by mistake, Right back to screwing up. replaced relays again, so far so good.... fickle things they are
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          made sure, they are all good.
                          • M-power1989
                            • Aug 2011
                            • 165
                            i had a similar problem turned out to be my rotor and distributor cap but it was a 1989 525i
                            • trackjunkie21
                              • Jan 2010
                              • 3962
                              none of that business on my m50.
