1991 318is
M50nv swap
I've searched the past week through threads on no start issues looking for clues. It cranks, I'm getting fuel and spark. Checked resistance on the crank sensor (538 ohms). Camshaft sensor (1260 ohms). DME has power at pin 26,21 and 56. I pulled the fuel rail up to confirm good spray from the injectors while cranking. Pulled a coil and popped the plug in it to confirm spark. I pulled the trigger wheel on the crank to confirm the alignment pin is there and that it is lined up.
Got any recommendations for me?
M50nv swap
