AHHH ive tried everything... still not running right
  • MattM
    • Apr 2009
    • 931
    M52b28, Full OBD2
    Engine runs like shit.
    It starts fine, idles about 500 for 10-20 seconds, then drops to around 250 for another 30 seconds, before it sputters out and dies.
    Throttle response has HUGE hesitation... literally like 20 seconds. If im quick and make it to the throttle and hold up open a bit, it will stay running...
    - quadruple checked all vacuum lines
    - cleaned ICV twice
    - cleaned throttle body
    - replaced MAF
    - replaced MAF boot
    - replaced fuel filter
    - replaced spark plugs
    One other interesting observation, header bank 1 (cyl 1,2,3) stays warm to the touch, while header bank 2 (cyl 4,5,6) gets SMOKING hot(normal temp?)
    HELP im getting really frustrated with this
    Full Build Thread Here
  • e30e
    • Dec 2004
    • 2176
    How's the fuses, dumb question I know....but with obd2 those fuses can be a mother fer......
    Other thought, is yes you've checked the vacuum lines but are they the correct places, are any of those lines in the wrong place?
    1985 BMW 325e
    1997 BMW M3/4/5
    2007 Chevy Silverado Crew Cab 5.3 v8
    • MattM
      • Apr 2009
      • 931
      which fuses are you referring too? not many fuses in the way of the engine running.... when it sputters out and dies i can go and turn the key and it will start back up again and repeat.
      Vacuum lines are all hooked up properly, i disconnected and plugged the hose that goes back to the exhaust valve just to eliminate that system from potential errors...
      • luckysnafu
        • Jun 2008
        • 262
        Can you hook up a code reader and get us the codes? It's pretty easy to wire up a connector for a generic OBD2 code reader.
        What happens to the idle when you disconnect the MAF?
        What are you running for an intake?
        M/S52 Wiring Diagrams
        Z3M S52 to late model 325i wiring diagram
        M52 to 318is wiring diagram
        • Boosted E30
          • Dec 2009
          • 288
          I bet you have a missfire on 456 and thats why the header gets so hot so fast. If you have a known working set of coils swap them out and see if it fixes it. Or change coils 456 with 123 and see if the 123 header gets super hot quickly.
          Also check the rubber boots that go from the coil to the plugs and see if there are any cracks in them that could cause them to arc.
          • Wanganstyle
            • 2828
            ok-
            start with the missing symptom; lets see if your engine is using ALL 6 cylinders!!!!!!
            Multimeter EACH coil pack and see what the 3 wires are showing:
            1 should be ground at all wires
            another will be 12v+ on IGN+ position power on
            another wire will be Direct to ECU and color coded.
            use Multimeter to check the above 3 items on all 6 coilpacks.
            then check for 12v+ at all injectors
            and for continuity between injector 1-6 and ECU.
            IF you have only HALF the cylinders hot when running, then something is not working uniform on your fueling/sparking.
            • MattM
              • Apr 2009
              • 931
              i have a code reader, the only code i am getting is fuel tank pressure sensor... its not hooked up
              Ill try some of this stuff tonight
              • Wanganstyle
                • 2828
                Code reader won't help u diagnose improper wiring mistakes, only useful for 100% original car to diagnose broken sensors etc
                Code reader is close to useless in many swaps, it cannot tell you if the harness is physically wrong.
                Multi meter or even a simple test light would show u the end of the tunnel....
                • ExViTermini
                  • Jan 2011
                  • 120
                  My obd1 m50 acted this same way. Twas the ecu.. :(
                  E30 m50/s52 turbo partout:
                  http://www.r3vlimited.com/board/showthread.php?t=236224
                  AEM EMS setup for BMW:
                  http://forums.bimmerforums.com/forum....php?t=1781886
                  • MattM
                    • Apr 2009
                    • 931
                    im almost 100% sure the harness is correct, i spent about 3 days in the ETM's marking and labeling everything, and writing a pinout for the x20
                    • Wanganstyle
                      • 2828
                      I am always like this......but multi-meter tells the TRUTH.
                      if 1/2 the cylinders are not running (as your symptoms seem to show) then 1/2 the cylinders are not getting fuel or spark.
                      if hand can touch headers, than those cylinders = not working.
                      I have always found some idiot simple mistake when I am 110% uuber sure of my self :P
                      last time I connected my Crank position sensor to oil level by accident and thought the DME was bad...
                      • MattM
                        • Apr 2009
                        • 931
                        well, sounds like im going to pull my intake mani off tomorrow and go through everything! If all is good ill assume the ECU...
                        • bimmerteck
                          • 762
                          Make sure the O2 sensors are installed into the correct banks. ;)
                          • etxxz
                            • Feb 2006
                            • 2085
                            1) ^^ yes.
                            2) my engine did that when i had huge vaccuum leaks. Try to rev it to keep it from dying, after a minute or so, does it idle steady? If so, you messed up some hoses, check all. specially those connected to the Idle control valve. Hell that could be the cause. BTW, if you're running obd2, you can't just get another ecu.. you'll need key and ewsII module as you probably already know.
                            3) Do you even get even firing or does it sound like a v-twin?
                            No more e30s for me.
                            88 black BMW OBDII 332is dedicated track [sold]
                            88 BMW OBDII bronzit 332is [RIP 03/08]
                            91 BMW 325i [sold]
                            86 Corolla 'Ae86' HB 20v trd [sold]
                            http://youtube.com/watch?v=pTj7Hn9v5Rs
                            • luckysnafu
                              • Jun 2008
                              • 262
                              If he can read codes there would be multiple codes thrown for having the O2 sensors switched. I had that problem when I installed new ones. The car still ran/idled and drove, just not very well.
