I found a m52b28 has a s5d320z manual transmission. The motor is off a 98 528i. What other manual trannys will fit as well? Which trannys are interchangeable?
M52 transmission
any tranny that bolts to any M/s5x block.... and the same rules apply for the 260 or any other e30 tranny... -
clutch kit, flywheel, pilot bearing
may or may not need a starter that matches the flywheel depending on the flywheel you getComment
nothing drastic between the 5 speed transmissions... the 6 speed is the ultimate choice, but they are harder to find and more expensive.Comment
