Transmission choice concerns & suggestions
  • Adrian_Visser
    • Jun 2006
    • 2823
    Lol no reason, I haven't switched em yet. My current trans has a pretty beat 2nd gear syncro but I have a spare 260 in the garage too. Mainly it was a junkyard find I couldn't resist. I'm a parts hoarder what can I say?
    Thanks to my bro for grabbing it for me.
    Hell the 2.79 needs a rebuild anyway, if they weren't so damn hard to find with LSD I'd just grab another one or a 2.93LSD.
    '89 Alpine S52 with goodies
    • rThor432
      • Feb 2007
      • 3907
      Originally posted by Adrian_Visser
      My bad, are both the Getrags identical?
      No, the E46 is supposed to have revised synchros. The Euro 6-speed is a nice gearbox and is not much heavier, but I don't think it's worth the extra $$. I have one in my E36, and the forward gears are pretty much the same as the ZF-- you only gain overdrive. If you can justify the extra $ for the trans and custom work to install it, go for it.
      • 328ijunkie
        • May 2007
        • 3961
        The 2 M3 6sp ones? No. E46 M3 uses a different spline count (dont recall off the top of my head what) on the clutch disc/input shaft and some other changes. Getrag E36 6sp box uses same clutch setup as the ZF 5sp's (for the most part).
        Check Us out on Facebook
        Full Product Line Tuning
        • Wanganstyle
          • 2828
          E46M 6mt uses V8/V12 size imput shaft to the trans. Same as V12 6mt and V8 6mt.
          E36M euro evo2 6mt uses same size imput as 5 speed items, so It can technically take a M20 clutch. It uses a S52 clutch natively; thus popular with e36m guys for compatibility.
          E46M 6mt can be fitted with S52 clutch set+fly+ s62 friction disc.
          • 328ijunkie
            • May 2007
            • 3961
            H, care to mention when they started doing the crazy shit with the flywheel mounted pilot bearings?
            • Wanganstyle
              • 2828
              06 or so in e46 lineup, I know the 330i aftermarket flywheels have the TOB pressed in like a subaru to the flywheel.
              s54 has the pilot bearing in the crankshaft, I prior ran a S52 fly+ clutch with it +zf 5mt (s52 = same setup as S50b32 6mt)
              • 328ijunkie
                • May 2007
                • 3961
                woot
                • nrubenstein
                  • 3148
                  Originally posted by hoveringuy
                  What's so great about the 6 speed?
                  G260 is kind of sluggish, especially in a single vanos motor. The gear spacing just kind of sucks. 6spd gets you better spacing.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    I have already decided to go 6sp. If you want to have your cake and eat it too, this is what you do.
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
