Anyone keep a tab on your swap costs?
  • freeride53
    • 11972
    I have started to compile a long list of everything I need for the swap.
    Just to get some ballparks, how many of you guys know roughly how much you spent total on your 24V swap? (m5x & s5x).
    Thanks!
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • scottinAZ
    • Dec 2009
    • 1312
    m50 swap with 5 speed conversion
    Engine, harness, alt and PS pump 1100
    Transmission, shifter, pedals, master cyl 220
    Radiator 125
    headers 90
    mounts, hoses, w/p gaskets, misc new parts from Blunt 600
    Oil pan 125
    Clutch and flywheel 125
    other shit Im forgetting
    Total spent just under 3k
    I saved 15% on my Bimmer parts by switching to ...
    • SkorcherX
      • Jun 2011
      • 267
      I am quickly approaching $1100 bucks. Will likely be around 1500 without exhaust work. 1987 325 5-speed.
      $420 for motor, all accessories, plus an e36 steering rack.
      $108 Ebay Headers
      $180 5-Series oil pan, dipstick and pick up
      $30 valve cover (mine was effed)
      $200 or so, for gaskets coilpack boots, serpentine belts, motor mounts, etc.
      $70 Single Mass flywheel
      $65 plug and pins for re-wiring M50 harness
      I have a few more nick-nacks to buy, fuel line, clutch, pressue plate, throw-out bearing, pilot bearing, shift linkage rebuild kit.
      Then I need to have my flywheel machined and resurfaced. Plus the exhaust work... soooo its adding up pretty quick. Helps that the car was only $300. And I hope to salvage some of the old M20 stuff for around $100 or so.
      • N2MYE30
        • Oct 2007
        • 5536
        $450 for M50NV with all accessories minus alt
        $200 oil pan and stuff
        $500 exhaust
        ~$300 blunt
        $85 tranny brace
        ~$100 pnp
        ~$100 auto zone
        ~$100 pizza
        -$350 for M20
        -$core of cat
        So I guess im about at $1500
        COTM
        • Beej '86 325es
          • 2639
          It's funny you post this. I just stumbled on an old spreadsheet today...
          Swap: 12,400
          Front suspension/brakes: 3,600
          Misc: 1,700
          Since then we've swapped everything to a new shell and I've done some other work totalling another 12,000-13,000.
          So I've sunk around 30k into my car in the last 6 years...which is quite depressing.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • Eric
            • 5141
            my swap cost a little over 10k :(
            • Adrian_Visser
              • Jun 2006
              • 2823
              Swap: 12,400
              Misc: 1,700
              Wow how did an s50 (US?) cost that much?
              '89 Alpine S52 with goodies
              • Beej '86 325es
                • 2639
                Easily :) Yes, S50B30US
                This is my tally from a couple years ago...
                S50 spendingItemPaidCylinder Head800Short Block700Pistons1000Wire Harness108Wire Adapter80Intake Manifold/TB214Exhaust Manifold125Water Hoses / misc.190506 ECU125Brake Booster80Brake Cylinder150Radiator640Cams10003.5 Euro HFM225Spec Clutch620Engine rebuild / labor2200E34 M50 Oil Pan260Cat-back Exhaust550OBDII cats225Vanos Gears100Gauge Cluster/trim60Eurosport Pullies175Knock Sensors60Hardware/Mounts 1217Cam Position Sensor46Backup chip140Hardware/Mounts 2175Alternator270PS Pump75Code Reader150Fuel Injectors160Hardware/Mounts 378Charcoal can / hose58Hardware/Mounts 375V.C. Powder Coat110Crank Sensor50Tranny Brace82Hardware/Mounts 4240Air Filter75Wideband O2400Starter160Battery150
                EDIT: Lesson learned...don't paste in Excel tables.
                -Brandon
                '86 325es S50
                For sale:
                • sohc12vm20
                  • Jan 2010
                  • 688
                  S52 with full obd1 conversion $3400. thats wit e28 mounts e21 mounts, e32 BB/ 535i MC. I still need wiring harness and making my transmission bracket. I running g260 and 3:73lsd wihich is already on the car. My muffler guy is gonna charge me $250 to setup me exhaust. So wen its done and said I'll have spent a hair under $4500 to do me s52 swap.
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    Engine $600
                    Maintenance and partial rebuild $600
                    Other swap parts, another 600 dollars
                    Around 2 grand? give or take.
                    Originally posted by Wh33lhop
                    VANOS: sometimes you just need to go full retard.
                    • nrubenstein
                      • 3148
                      Swap cost depends largely on whether or not you succumb to whileI'minthereitis. It can really multiply the cost of things.
                      2002 BMW M3 Alpinweiß/Black
                      1999 323i GTS2 Alpinweiß
                      1995 M3 Dakargelb/Black
                      - S50B32/S6S420G/3.91
                      1990 325is Brilliantrot/Tan
                      1989 M3 Alpinweiß/Black
                      • Eecen
                        • Jun 2010
                        • 1235
                        And if you aren't doing the "whileiminthere" you're half-assing things.
                        • Danny
                          • 14216
                          I think I spent around 4k including engine on my s50 swap.
                          • samiam3356
                            • Jul 2009
                            • 1901
                            s52 OBD1
                            New Rack
                            5lug swap
                            rebuilt 3.46 lsd
                            sport seats
                            AST 4100's
                            style 5's
                            Stromung cat back
                            Custom dual exhaust
                            ~14k because While I'm in there required such things! lol
                            Originally posted by Roysneon
                            $5 shipped?
                            Originally posted by MarkD
                            You are a strange dude, I'n not answering any more posts from you.
                            • Leo_328i
                              • 226
                              I think it also depends a lot on how you look at it.
                              I'm about to take the plunge on the 24v swap. One of the new things I'll get is a new clutch but the one on my M42 is currently shagged so I would have had to incur that expense anyway. IMO not really a cost directly associated with the 24v swap.
                              For me so far.... (keep in mind Australian stuff is expensive as hell). Prices in Australian Dollars which is roughly worth 5% more than USD at the moment.
                              $800 - M52 2.5l alloy block with 90% sensors, E36 arms, alternator, PS pump, AC, harness etc
                              $100 - E36 rack and tie rods
                              $120 - E28 M5 mounts
                              $50 - Full E36 328i exhaust system (bargain!)
                              $30 - E46 M3 trans bushes
                              Soon to be incurred:
                              OBD2 ECU - $150
                              E36 323i/325i clutch - $300 approx
                              E36 228mm DMF (used) - not doing M20 flywheel - $50
                              Various new sensors/pulleys/waterpump - Minimum $250
                              Bimmerworld M50 intake adapter kit - $180
                              M50 inlet manifold - $100
                              Exhaust modification costs - Minimum $100
                              E34 M50 pan/pickup - $200
                              My goal was to do this for less than $2000 so it looks like I'll be just over....
                              If you discount the clutch expense because it needed to be done anyway then I'm very close to budget :)
                              EDIT: Transplant into 1990 318iS
                              Leo.
                              E30 318iS, E36 328i
