IAT - Is it possible for this sensor to cause misfire?
  • dude8383
    • Jan 2005
    • 10387
    For reference:
    13621725323
    Is this thing capable of causing a misfire? I'm just trying to diagnose the misfire issue on my S52. The donor car ran smooth as butter prior to the OBD1 swap... which has me convinced that either my MAF is faulty or the IAT is.
    The reasoning behind this is the fact that when my stroker blew up, it regurgitated coolant out of the air intake. So far, cleaning the MAF has improved the way the car runs but still suffers from a misfire. I have a MAF thats in the mail already, should have it tomorrow.
    So do you guys think that coolant passing over the IAT could have possibly made it malfunction? I cleaned the intake manifold thoroughly with brake cleaner and flushed it with water as well...let it dry overnight and installed it.
  • dude8383
    • Jan 2005
    • 10387
    Quick update, I checked resistance for both the sensor thats in there now and the new one... both are reading within spec it seems.
    This issue is really beginning to point at the MAF
      • 37832
      You don't know anyone with a MAF you could test with?
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • 328ijunkie
        • May 2007
        • 3961
        Unplug the MAF. Try running it like that for a little and see how it runs.
        Check Us out on Facebook
        Full Product Line Tuning
        • dude8383
          • Jan 2005
          • 10387
          My buddy has an e36 325I but his maf ain't functioning properly either. I've been trying to find someone locally that I could lend one but haven't had any luck. Might have to stop by my buddy's place in Jersey.
          Unplugging it makes it run smoothly. Is it okay to drive it like that??
          Another strange observation, when swapping MAF sensors the car runs smoothly for the first 2-5min at idle. As soon as I give it any throttle input it begins to misfire...
          MAF right?
          • 328ijunkie
            • May 2007
            • 3961
            Its okay to run with no MAF, not idea but it doesnt hurt anything. The ECU defaults to a safe map because it has no idea how much air is coming into the engine.
            This is not "Alpha-N" as some people assume.
            • dude8383
              • Jan 2005
              • 10387
              Interesting. Good to know!
              Also started a thread on bf:
              The game plan is to swap plugs as soon as I get home. I completely overlooked the fact that the car ran SUPER rich prior to cleaning the MAF.
              • trackjunkie21
                • Jan 2010
                • 3962
                IAT wouldn't cause it to misfire, it would have a weird Idle, but it shouldn't be causing anything like that. A combination of plugs and the MAF can be causing your car to be running rich, I would swap out plugs either way, The NGK's are your best bet. part number: 12-12-9-064-619-M220. Bosch 4 tip plugs are a waste.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • 328ijunkie
                  • May 2007
                  • 3961
                  NGK Vpower: 2.10 at AAP!
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    Unplugging the MAF and it running smoother means you have a mixture issue, (MAF, O2, Or Coolant Temp)
                    Check all 3. You can meter the MAF while it is running with a volt meter set on 20VDC.
                    The O2 you can monitor also with a meter. You should use a watch to check it out though.
                    Coolant temp also with a DVM. Its resistance based.
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • dude8383
                      • Jan 2005
                      • 10387
                      Yeh, I'm slowly ruling that out as the cause.
                      Definitely going to pick up those NGK's when I get back from the track, for now, I will swap out to the Bosch plugs I have that are NIB.
                      Are these single tip?
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Yes.
                        • dude8383
                          • Jan 2005
                          • 10387
                          Should I have the car running when checking the MAF? Or just with ignition on? I did test the MAF though, its getting proper voltage. Unless I'm completely missing your point.
                          Not sure how to check o2 sensor though. Am I checking for power at a specific place?
                          Coolant temp I will definitely check for resistance. The dual pin one correct?
                          • dude8383
                            • Jan 2005
                            • 10387
                            Yes.
                            I thought the 2 tip ones were better? In any case, I could probably snatch these up on my way down to Shenandoah.
                            • 328ijunkie
                              • May 2007
                              • 3961
                              I prefer the single's
                              Oh and you want to measure MAF voltage going back to the ECU when the engine is running. It sends a 0 to 5 volt signal back to the ECU based on how much air is coming in.
