No fuel.
  • dball4
    • 560
    Was not unplugged. Would no spark void the fuel pump from engaging?
    1989 M3
    2008 135i 6sp
    • MattM
      • Apr 2009
      • 931
      they usually go hand in hand, its the DME's way to disable the engine if its not happy with itself. Usually sensors hooked up wrong or not at all.
      Full Build Thread Here
      • E30_pilot
        • Sep 2005
        • 1461
        Pull the fuel feed line. Its the line that goes to the front of the head. Fuel will pour out so have a rag ready.Put fuel line in a empty water bottle. Now clean any fuel spillage and go try to start it for a second.
        If fuel comes out then your pump is fine. Problem is in the injectors. Check to make sure ground connections for injectors are good. This is happened to me. Car was running parked it and stopped working. Check the ground and found it loose. Retighten it and fired right up.
        -Frank
        1987 325is m50nv (schwarz)
        1990 325is (sterling silber)(sold)
        2001 525i
