e32 735i brake boost intermediate peice
  • blueapplesoda
    • Dec 2005
    • 1904
    Does anyone know where I can find one of these? It's the spacer in between the brake booster and the firewall. I purchased a booster and it came without this spacer. The boneyard has one, but I wanted to ask here first before I have to dissect the 7 at the yard and battle the vultures.
    pn: 34331160561 or 34331157105
  • 328ijunkie
    • May 2007
    • 3961
    I have a few laying around. I dont use em.
    Check Us out on Facebook
    Full Product Line Tuning
    • Adrian_Visser
      • Jun 2006
      • 2823
      If you chop and weld the rod you don't need that spacer, it gives you extra room in the engine bay as well.
      '89 Alpine S52 with goodies
        • 37832
        Derek, junkyard is your best bet. I may actually have a booster with one at home, can't remember.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Zesty Bonanza
          • Apr 2011
          • 88
          I'm also looking for the spacer piece (part number 34331157105). Anyone have one for sale?
          Cutting the rod and welding it could work, but then the holes on the firewall won't match the brake booster's bolt pattern.
          • j.m.
            • Oct 2015
            • 6
            Digging this up from the grave.. Any of you guys still have the adapter part? Looking for the 2 bolt to 4 stud version p/N 34331157105
