so i have a m50 vinos swap with 3.0 cams and over reved it today.. i have a hissing or maybe light scraping sound now and all compression is at 100 exept one by fire wall is at 60 .. what do i do and where to start??
Over rev help
Pull cyl head.
Check Us out on Facebook
Full Product Line Tuning
You should stop now.
Bent valves would be my guess. No, there's not a master link on the timing chain. You need to pick up a Bently manual, maybe the '101 Performance Projects for you 3 Series BMW' book.Originally posted by LJ851kingston is the play by play announcer for this thread.
Originally posted by unloadedak#teamross
Originally posted by 328ijunkie View PostYou should stop now.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
Originally posted by MattM View Postjeez guys, give him a break, i looked for a master link the first time i played with one too... Its an honest thing to do...
Ya I was terrible my first time too its kewlsigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
Originally posted by kbdrake07 View Postso i have a m50 vinos swap with 3.0 cams and over reved it today.. i have a hissing or maybe light scraping sound now and all compression is at 100 exept one by fire wall is at 60 .. what do i do and where to start??Leo.
E30 318iS, E36 328i
Some cars actually have a master link, so if I has worked on other cars besides BMW's I can understand why he would think that.
Get a Bentley for the E36 M3 and use that to pull your head. Also invest in the cam locking tool and the cam turning tool.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Originally posted by jrdeamicis View PostGet a Bentley for the E36 M3 and use that to pull your head. Also invest in the cam locking tool and the cam turning tool.Originally posted by LJ851kingston is the play by play announcer for this thread.
