Do I leave this plate on?
  • sohc12vm20
    • Jan 2010
    • 688
    The M50 didn't have one.. the M50 and S52 oil pans look a like inside. So my guess is leave it as is, However I have come across some people that say take it off.. I couldn't edit picture but for those who don't know what im asking it is the plate that's covering the crank shaft.. thanks r3v:)
  • bmwguy325is
    • May 2011
    • 1263
    Leave it on helps with oiling stuff.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • greyis89
      • 230
      From my research I found take it off the motor becasue the e34 pan has this already in it. Don't see why one would need two...
      • sohc12vm20
        • Jan 2010
        • 688
        Thanks!
        • sohc12vm20
          • Jan 2010
          • 688
          yea the m50 pan i picked up, doesn't have that piece inside.. so I will leave it on.
          • AndrewK
            • 37
            Strange. On my E34 pan I'm almost certain it was riveted on. Called a windage tray. Helps prevent the crank from whipping the oil into a froth. You definitely want one or the other.
            If you keep what you've got there, you may need to remove the bracket that is sticking out to give you enough clearance to the E34 pan. Just bend it back and forth till it breaks off.
            Bodykit courtesy of BMW M GmbH.
            • sohc12vm20
              • Jan 2010
              • 688
              Yea I had to remove the bracket. I think I should leave it on because the s52 didn't have that part in the oil pan and neither does the m50.
              • Pudmunkie
                • 210
                Post a picture of the inside of your e34 oil pan, it should have it riveted in. The normal e36 pan will not have it.
                Sent from tablet in ('rooted','nook','cm7')
                • N2MYE30
                  • Oct 2007
                  • 5536
                  My windage tray on my e34 pan was riveted in and was removed.
                  COTM
                  • kingston
                    • Jun 2010
                    • 2669
                    Mine was removed from the pan before I got it, too. To clarify, you can EITHER use the one on the engine, or the one in the pan. You can NOT use both (the pan won't fit on if you try).
                    Originally posted by LJ851
                    kingston is the play by play announcer for this thread.
                    ‘Tis by the grace of God that my cars run!
                    Originally posted by unloadedak
                    #teamross
                    Siobhan's Build Thread - UPDATED!
                    • Pudmunkie
                      • 210
                      Ok, so assuming you had a choice between the baffle in the pan, and the one bolted to the motor... Which one would everyone pick?
                      • Philo
                        Ich esse kleine Kinder
                        • 3334
                        Some of the oil pans had the windage tray, some didn't. You can use either the one on the oil pan, or the engine, but not both as previously stated.
                        -tim
                        Originally posted by Jordan
                        I like the stance
                        • sohc12vm20
                          • Jan 2010
                          • 688
                          I put my pan on already, so no pictures of the pan inside. Talked with my mechanic from BMW, advise me to leave that plate bolted to the engine because the M50 oil pan was exactly like me s52 pan, didn't have that baffle or whatever its called in it. So it stays as it was prior to oil pan swap. Anybody knows if because its a M50NV pan is the reason for that piece not being in there. As long as me engine stays top, I'm OK:).
                          • scottinAZ
                            • Dec 2009
                            • 1312
                            my pan was from a 92 NV motor and had the windage tray in it. I removed the one from the engine, and kept the one in the pan.
                            As previously stated, use one or the other, not both
                            I saved 15% on my Bimmer parts by switching to ...
                            • Fusion
                              • Nov 2009
                              • 3658
                              Didn't someone here have a problem with the crank hitting the tray and making knocking noises?
                              I can't recall what was wrong that made it hit.
