The Grand Vanos VS. Non-Vanos Thread
  • nrubenstein
    • 3148
    Originally posted by Wh33lhop
    It's a waste of time and money putting a newer, more powerful, more efficient motor with more midrange (Vanos) that requires no timing belt replacements, no valve adjustments, in which a belt change takes 30 seconds, a water pump swap takes 10 minutes, the oil filter is easily accessible and not underneath exhaust manifolds into an E30?
    Man, I fucked up. ;)
    I know what you are going to say. Oil pump nut, low hanging oil pan, a little more weight over the front axle, smog, no oil cooler, theoretical 20hp increase, M20 oil filter housing can be flipped around. The point is, the swap is not without its merits, and you are getting built M20 power without even touching the internals of the motor. Throw in the tired state that a lot of M20s are in these days (mine put down 129whp with chip and injectors I think) and it does not seem to be such a horrible idea. Do not expect a fast car, but instead just a marginal increase.
    *shrug* The best thing about an M50 swap is that you have already done all the work to swap in an engine that delivers enough power to make it worth it. (Anither point against the NV engine.)
    Your points are valid, I just don't really see the point of putting all that work in without at *least* going to a cammed 2.8.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • e30trooper
      • 11576
      Originally posted by MaxBell
      It's not as reliable as VTEC, but it's essentially the same idea.
      I feel like swapping an M50 is only really a worth while endeavor if giving yourself Vanos. With Biesan Systems doing a $60 rebuild kit, there's not really any downsides. I just wish there were more performance upgrades that were not engine swaps or turbos. BMW does too good a job tuning their engines, we have nothing to do...
      I was out with some friends who run swapped M50 E30s, and they all say the beefier non-vanos is a bunch of ancient mis-information. They've rebuilt them, not me, so I'm going of their word.
      yeah i know vanos is not vtec, i was joking. There are plenty of "upgrades with out swapping or turbos" for a m20, it just cost alot. A MAF kitted m20 with give any m50 a hard time allday long. I had a m50tu once but it was in a 94 325is, the car pulled but not as hard as my chipped rebuilt m20.
      • Fusion
        • Nov 2009
        • 3659
        M50 vanos or not are low maintenance well powered engines for what they cost.
        If I blow mine, I'll just go look through ads and have it swapped within a week, for the price of a good dinner.
        Both are also a good first step towards S5x, where you can't really afford to fuck up.
        • Wh33lhop
          • 11705
          If anyone is in my area with a lightly modded M20 car, I welcome some friendly competition. I haven't had a huge number of run ins with M20 cars, but every M20 (and S14) car I've gone up against I've taken. I don't regard my car as fast by any means, but when I drive an M20 car it feels like a bit of a dog compared to my internally stock, 210k mile, non vanos, oil burning M50 breathing through a hot-air cone filter and stock M20 exhaust.
          Again, I recognize that my sample set is pretty small and a lot of people do not know what they are doing so I am up for some challenges if anyone is in the area. :p
          The only difference between an M50TU -> S50 swap and M50NV -> S50 swap is that you will need a different harness. Really if you know what you are doing the 24v swap is not much more difficult than just an engine pull/install. Just gotta frankenstein the right parts together, do simple wiring and figure out your exhaust. May need another radiator if you're an early model.
          paint sucks
          • AnimalE30
            • Aug 2009
            • 266
            VANOS vs. Non-VANOS was settled a long time ago in ITS. The VANOS cars were beating the NV cars.
            Anyway, an M50 swap is still a waste of time and money. You're making real compromises for not very much gain.
            Putting an m50 in my car with only help from my brother was one of the best experiences of my life. Worth the money.
            Also, if you're going turbo - a vanos will spool faster. That right there is worth the added complications of the unit.
            • MaxBell
              • 1391
              I think the big thing is that my M20 is so sluggish that rather then rebuilding and MAFing that, I'd rather have the more modern engine, a little extra hp and the better base to turbo.
              REMEMBER: Be safe and have fun is Rule Number 1.
              The Epic Unbuild of Clint Eastwood
              • Adrian_Visser
                • Jun 2006
                • 2823
                VANOS and V-tec are similar only in that they are both methods of varying valve timing.
                VANOS only advances or retards the opening point of the intake cam (on single VANOS).
                V-tec varies timing, lift and duration of the cam. It activates a whole different lobe on the cam actually.
                VANOS is kinda an old shoe compared to V-tec sorry to say, especially the on/off single VANOS in an m50tu.
                Have you read this thread?
                Wh33lhop spells it out pretty clearly in his post there.
                I have never heard of running a shrick cam in the exhaust side, nor swapping an exhaust cam into the intake. The only "hot" cam setup I have heard of is running an second intake cam in the exhaust side.
                FYI an s50 block is identical to an m50TU block and s50 bore is 86mm. If BMW was boring m50TU blocks to 86mm from the factory it must be safe no?
                '89 Alpine S52 with goodies
                • e30polak
                  • 6136
                  No comparison here:
                  The Vanos motors are better in EVERY aspect, even price. For the $200-300 more you'll spend on an M50TU vs. a M50NV, it's well worth it. Why?
                  Vanos motors have greater power potential in NA form, with huge aftermarket support, as well as a lighter rotating assembly.
                  Also the argument that NV is better for boost is a bunch of BS. Sure you can run Megsquirt on a NV motor and tune it with more ease then trying to do the same with a Vanos motor, however it wont spool as quick or be nearly as potent as a Vanos motor with the same set-up. With so many tuners now that offering affordable tuning options for turbo Vanos motors, it's simply the better choice.
                  INSTAGRAM: @UNDR8D_EMPIRE
                  • DÌEGØ
                    • 690
                    Sub'd!!! Because my next project might just include 24V of some sort
                    Driving:1990 325iS, 2007 335i :devil:
                    past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
                    • mazur
                      • Jan 2006
                      • 731
                      Next thread should be M50 vs. S50. Is it worth the trouble to go with just an M50?
                      Answer: NO
                      • MaxBell
                        • 1391
                        Answer: NO
                        ooOOOoo...good question!
                        • e30polak
                          • 6136
                          Answer: NO
                          Not with the price of S50/2s these days. :p
                          • herbivor
                            • Apr 2009
                            • 1420
                            My M50 non vanos FWIW.
                            Had a slight vacuum leak at the time. Running catless. Don't forget, this is RWHP.
                            My car seems plenty quick as a DD. Anything much more would require some chassis stiffening and wider wheels I think.
                            • E30_pilot
                              • Sep 2005
                              • 1461
                              I've been in a vanos swapped e30 at an autox event about a year ago? And after finishing my nonvanos swap I don't really see/feel the difference. But then again it was a year when I was in the vanos car.
                              Now why did I go with a nonvanos over vanos or even a s50? Simple. My nv m50 costed me 500 delivered and came with an engine stand. It came from a auto e34 with 150k so I know it wasn't abused.
                              And if or when I get "bored" of it, I have a turbo manifold from good&tight sitting in my garage just waiting. And of I get bored of that I can swap the basics over to a s50(hopefully prices will drop) and throw the m50 into my other car lol
                              -Frank
                              1987 325is m50nv (schwarz)
                              1990 325is (sterling silber)(sold)
                              2001 525i
                              • Jand3rson
                                • 37587
                                Costed? :D
                                But my reasons for the NV were the same, got the whole engine with E34 oil pan/dipstick, E36 arms, ECU, and wiring harness for $700 delivered (well, halfway), it was too good of a deal to pass up, and within my budget. From an auto car, low miles, great looking internals. Doesn't mean I can't change it up later.
