ZF shift pin tools
  • Gooch
    • Dec 2006
    • 1674
    ZF shift pin tools
    Any fellow r3vers have the ZF shift pin tools that they would kindly rent out? I'm looking to do this pretty soon, I have all the parts and I'd prefer to use the correct drift tools for the job.
    For those that don't know, here's a great article on how to replace them:
    http://webspace.ringling.edu/~dplassma/bmw_diy/shift_pins/shift_pins.html
    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
    '87 535i - Vacuum brake conversion [SOLD]
    '93 525iT - 5-speed swap - 320k and counting
    '09 328xi - 6-speed
  • 328ijunkie
    • May 2007
    • 3961
    PM me. Ive got a set of em.
    Check Us out on Facebook
    Full Product Line Tuning
    • Gooch
      • Dec 2006
      • 1674
      Done, thanks!
      '09 328xi - 6-speed
      • dude8383
        • Jan 2005
        • 10387
        I wish I would know you had a set Dave. I managed to replace reverse and 5th gear shift pins using a few ghetto fabulous methods...
        • 328ijunkie
          • May 2007
          • 3961
          haha first time i did them i did the same and after that disaster got a set of the drifts haha.
          • samiam3356
            • Jul 2009
            • 1901
            interesting! THx for posting
            Originally posted by Roysneon
            $5 shipped?
            Originally posted by MarkD
            You are a strange dude, I'n not answering any more posts from you.
            • e30rapidic
              • 2167
              I did mine in the car....without special tools. ugh. I created a few new swear words in the process.
              '87 325ic, powered by S50.
              • 328ijunkie
                • May 2007
                • 3961
                No fng way.
                • dude8383
                  • Jan 2005
                  • 10387
                  Originally posted by 328ijunkie
                  No fng way.
                  X2. How?? That's crazy, there's like no room in the tunnel!!
                  I r impressed.
                  • e30rapidic
                    • 2167
                    No fng way.
                    I r impressed.
                    it would have been less hassle to unbolt both subframes, trans, drive line, diff and all suspension and lift the car body up than to do it in the car. It involved bent nose pliers and a small screwdriver to pull the sleeve out, two broken thumb nails and various socket sizes to tap the new sleeve in. Trying to put the circlip in while pushing at a funky angle under the car ain't fun!!! I did it but next time I will drop the trans, hopefully this won't need to happen. It is certainly too much trouble to do without removing and takes a lot of time.
                    If you have a zf trans and you are thinking of throwing it in, do yourself a favor and replace the $14 worth of parts before bolting the trans up. Not changing the springs/sleeves is like not changing a rear main seal when throwing a used engine in. Preventative.
