OBD2 FP reg placement options
  • Mr.SWISS
    • Nov 2005
    • 1251
    OBD2 Guys where are you putting your remote fuel pressure regulators? On the Z3 it had a place for it already to bolt up but on the E30 it seems the best out of the way spot is in under the booster and steering knuckle where the plastic holder is for the two metal fuel lines. What other places seem to work out? Will be going turbo so I would like it where it won't get in the way.
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
  • 328ijunkie
    • May 2007
    • 3961
    OBD1 fuel rail.
    Check Us out on Facebook
    Full Product Line Tuning
    • MattM
      • Apr 2009
      • 931
      or 528 fuel rail
      Full Build Thread Here
      • Mr.SWISS
        • Nov 2005
        • 1251
        Well I already installed it under the booster. But the more I think about the more I think I'd prefer the simpler setup.....
        :nice:
        • MattM
          • Apr 2009
          • 931
          i had one too originally and installed it in basically the same spot it was in on the e36... right under the drivers side floor.
