Alright guys,
I've searched a bunch and just need confirmation so I can troubleshoot elsewhere. My car has zero power steering at the moment.
Are my power steering lines hooked up correctly here:
Or here:
In both pictures the line going from the pump to the rack is is hooked up to the smaller banjo bolt, which is on the top in my 95 M3 rack. The skinny line going back to the res is on the bottom larger banjo bolt.
Im guessing the first picture is correct? the banjo bolts seem to fit better in the lines than in picture two.
Im just not sure because real oem has me confused:
The picture shows the larger banjo bolt on the top. The large banjo bolt on my pump and my brothers pump is on the side.
I'm guessing my pump was fine, but since I ran it like picture two for too long I ruined the pump - there was no difference in power assistance when I changed the line around.
Lastly does the pump to rack line have to flow a certain direction? How can you tell if you have the orientation right? I have mine the way it is because it was the first way I could get it to fit around the engine mounting arm.
Thanks,
Or here:
Thanks,
