odd situation clutch related
    so g/f was driving our s52 car home the other day, and slave came apart. The shaft is stuck in the pivot arm. belive it wore a whole threw the arm and is now lodged in the dreaded beast.
    So with out heating or yanking the piss out of it suggestions? rather not drop it but thinking I will have too.
    If it did wear a hole in the pivot arm, you are going to have to drop it to replace that. I feel your pain though, it is no fun dropping the trans on a swapped car, especially if it is a ZF.
    -Justin
    Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
      New clutch fork is in your future.
      Check Us out on Facebook
      Full Product Line Tuning
        Had a feeling it was that. Already removed it all and need to install it, but have to a wait a few days till I can do that.
