First off, thank you for the response. When I pulled the IM and valve cover, and peered down into the cylinder, I did not see any scour marks on the piston the would be indicative of valve-piston contact, nor did a magnet pull any metallic debris . Is it possible that the stuck portion of the valvetrain is preventing the cam from turning past that point (opening the #4 exhaust valves?) and that is the resistance I am feeling?
need help, knocking noise
I am not entirely sure about the valve train preventing the cam from turning. it shouldn't. pretty simple set up. I spoke with a buddy of mine and he says if you can't manually crank the car over and there is binding he thinks a valve is stuck open.
I would check the lifter; it's quite possible it might only be sticking.
Find out if there is some lubricant you can put into the valvetrain to free up a sticky valve. Aside from the noise, it doesn't seem like you are damaging the engine with the exception of the spark plug closing.sigpicComment
and that could've just been me gapping it too closely like an idiot.
My finger pointed to a closed exhaust valve because the cylinder was wet on top, leading me to believe that any fuel being injected wasn't being allow to vent."Broke into the wrong God damn rec room, didn't ya you bastard!"Comment
if it is staying closed; remove the valve cover. Crank the motor to see if the cams are spinning. as the motor is cranking put your finger inside to see if the valve is dropping. Do this procedure slowly manually cranking the engine. You have to check this to see if your valves in #4 is doing what they are supposed too.sigpicComment
Start by pulling cams/trays. Youll be able to tell if a lifter is Fed or a valve is staying open thats not under load.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Well it's official, I am now totally lost. I decided to do a compression test to see if one cylinder had zero psi and then I would know a valve was stuck open. I performed the test in less than ideal conditions:
I only let it idle to warm up (wanted to minimize revving it)
I ran the test when it was just past the cold mark
and like an idiot I forgot to leave the throttle wide open
Oh well this was just to see if a valve was stuck
the results:
1: 195
2: 170
3: 198
4: 188
5: 195
6: 195
So other than cyl #2 being low (but not alarmingly low, and the car barely burns oil) WHAT IS THIS TICKING COMING FROM? If the motor is revved the ticking increases steadily, which to me says valvetrain. And it doesn't sound like lifter tick, the noise is pretty damn loud. Here's another vid:
:wave
That sounds more toward teh rear like clutch/fly that motor knock. I had a car once that sounded like that, one of the tq converter bolts backed out a tad and was hitting the sheet metal dust cover. I know there is a difference in what you are working with but perhaps you didn't grind the pan down enough and it's hitting the fly in one particular spot.......
Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
never dropped the exhaust to peak into it huh? it's not going to be easy or a miracle to fix man...face the reality..start digging... :-)sigpicComment
