24v question. need help
    almost have it up to run, just missing a little bit of information.
    I do not know what hose plugs into the side of 9 and also for 11
    also where does hose 3 and 5 go?
    thanks guys
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    9 goes to the ICV, (big turkey necked lookin fucker), small hose goes to the bottom of the oil separator on the valve cover (top front of the cover, 2 hoses, one here #5, other big one to the bottom of the intake boot #3 in your second drawing)
    11 goes to the fuel pressure regulator IIRC, however this one Im not sure on
    I saved 15% on my Bimmer parts by switching to ...
      awsome man thanks
        Correct and correct.
        Check Us out on Facebook
        Full Product Line Tuning
          5 >small line on 9
          3>one of the lines on rubber intake, there are 2, and the other goes to the ICV
          Originally posted by Roysneon
          $5 shipped?
          Originally posted by MarkD
          You are a strange dude, I'n not answering any more posts from you.
