240 or 260
  • 328ijunkie
    • May 2007
    • 3961
    Zf320>g260>g250>g240.
    Check Us out on Facebook
    Full Product Line Tuning
    • shiboujin
      • Feb 2006
      • 2791
      I'd swap the 250 and 240.
      Although, I have gotten emails from sweden and the guys ask me why we hate on the 250. I've never seen one break either.
      • Mr.SWISS
        • Nov 2005
        • 1251
        Originally posted by 328ijunkie
        Zf320>g260>g240>g250.
        :nice:
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • 328ijunkie
          • May 2007
          • 3961
          I have a local track customer that runs SE36 and i sell him another G250 every year.
          • Philo
            Ich esse kleine Kinder
            • 3334
            Nah. ZF320>g250>g260>g240. You guys are whack. Closed ratio and proper oil displacement FTW.
            -tim
            Originally posted by Jordan
            I like the stance
            • Leo_328i
              • 226
              What on earth is with this G240 hate?
              A lot of guys run 240 gearboxes with 24v swaps and I've never heard of one breaking unless they were abused or behind an engine that was highly modified (eg. forced induction).
              Not to mention that you can use the stock transmission mounts which reduces your costs.
              G240s are quieter than G260s as well if you're after something for a daily driver car. I will be using a 240 gearbox for my 2.5l 24v swap later this year as the G240 has been behind USA S50 motors without issues.
              G250 gearboxes I heard are weaker than 240s but I may be wrong.
              Leo.
              E30 318iS, E36 328i
              • psyber_0ptix
                • 904
                lots of speculation being thrown around in the thread. I just say run what's available to you, and worry about it when you break the trans driving like an asshat
                Originally posted by FredK
                However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
                My year in Germany
                Feedback
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  Originally posted by flyboyx
                  this is a question that is honestly not worth asking. not to mention the fact the 240 is the weaker of the two, it is also a few inches shorter than a 260. what will you do for a driveshaft? will you waste a few hundred on a custom length one and run a weaker trans to boot? not likely.
                  e36 325i dshaft works, And never had a problem with the g240.
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • Wanganstyle
                    • 2828
                    perhaps try G220 i think. its close ratio and silly light. (318ti e36 and perhaps m42 e36 318?) its the e36 updated non overdrive version of e30 318is gearbox. should pair well with euro spec 316i flywheel and clutch lol
                    for boosting you prob. want something with a high enough torque rating to handle it - OP what are you planning to put down to the wheels, and what RPM range are you targeting?
                    zf320 is pnp with with its 24v engine anywhere a g260 was with its 12v engine, who cares if a driveshaft swap is required- you get a better guibo also. dual mass flywheel is a good thing, its actually great for turbo also- s52 oem clutch and 22lb fly would be the one to get. it can take a boosted 24v 2500cc straight up as is. OEM complete s52 clutch setup is even a good option for a turbo M20 as it fits right into the g260 and can be Driven through third world country traffic and also wangan'ed
                    s52 clutch is same PN as euro S50b32...
