Ok been searching here, tech, and google for the answer. And can't get a defined answer.
M50tub25 block
M52b28 crank
M52b28 or other 135mm rods
M50tub25 pistons
This combination yealds a working high compression m50 correct?
When everyone talks about it there is no
Clear answer on pistons being vanos or non vanos
An everyone says use m52b28 pistons too but I'm looking for higher compression. Not just a obd1 style b28 motor.
Thanks guys
M50tub25 block
M52b28 crank
M50tub25 pistons
Thanks guys
