Couple random questions
  • equate975
    • Jun 2004
    • 3382
    I had a couple things I needed to clear up quick. One is with the fuel lines.
    If you look at this pic
    The far right metal tube connects to a rubber hose that went to some sort of fuel strainer on the s14. What do I do with this? Its just connecting to nothing now.
    Also, for the clutch... Where does the brake res hook into it? I see the nipple you would clamp a hose on to, but where is it???
    Rollin' with a Geistkuchen
  • equate975
    • Jun 2004
    • 3382
    NVM on the clutch im just retarded, the hose for it got jammed behind the noise dampener and I couldnt find it lol
