Need a quick yay or nay.
  • 86325LSD
    • Aug 2004
    • 296
    http://www.ebay.com/itm/140498794075...84.m1423.l2649
    going to order these today. I am 99% confident they are the right ones, but with the community here I figured it couldn't hurt to ask before i drop the waffleswaffleswaffles.
    Thanks
    faint in, throttle out.
  • jclar
    • 265
    Those should be it, 50$ for both is a little worrying though, I think I paid like 40$ each for oem mounts.
    '86 325es M50
    • ZM Blue Devil
      • Dec 2006
      • 13836
      those will last you about a month.
      Levent
      %20levent@gutenparts.com
      Ladies:
      • 328ijunkie
        • May 2007
        • 3961
        I get them for like 15$... :dunno
        Check Us out on Facebook
        Full Product Line Tuning
        • ACHTUNG
          • May 2005
          • 2397
          I got mine for $25 brand new
          1989 US E30 Cammed S52
          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
          • ACHTUNG
            • May 2005
            • 2397
            Yeah, you should look at silence's 24v mounts instead if you have the extra cash:
            • kalib0y
              • Dec 2004
              • 3620
              In my E30, Ive done quite a few track days on them and had not problems. I even had them shimmed up a bit to clear long tube headers. But If i were to do it again, I would have used the AKG mounts just for piece of mind
              95 7.1L 16V E36 M3
              Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
              LIKE my Facebook Page! CLICK HERE
              • rlddlr53
                • Oct 2009
                • 1450
                e46 m3 mounts
                • Pudmunkie
                  • 210
                  Originally posted by rlddlr53
                  e46 m3 mounts
                  Does anyone have pictures of these installed? Maybe measurements compares to the e28s?
                  You're only the second person I've seen mention them
                  Sent from {smartphone;}
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    Almost 6 months on mine without any sign of problems.
                    Originally posted by Wh33lhop
                    VANOS: sometimes you just need to go full retard.
                    • BusyMrE30
                      • Feb 2011
                      • 55
                      I used m5 no problem yet
                      • TimKninja
                        • 2131
                        There has been signs of premature failure with these. Due to the weird design . Ive been told e34 525i mounts work fine. And their cheaper.
                        1985 325e M50TU(Sold)
                        1991 318is Slicktop (Sold)
                        1990 325is Brilliantrot S50/5 Lug Swapped.
                        1992 525i Manual shitbox Winter Beater
                        • jclar
                          • 265
                          He means the fleabay ones guys, not OEM M5 mounts.
                          '86 325es M50
                          • rlddlr53
                            • Oct 2009
                            • 1450
                            e46 m3 mounts will allow enough clearance to run a fan clutch
                            • surebimmer
                              • Jan 2004
                              • 978
                              i keep saying NO.
