I have checked for vacum leaks and even broke down and bought a gauge. I see over 25 in/hg of vacuum which is better than everage.
I have checked my fuel pump and it showed a little high at the rail but it did jump as it is supposed to when I dsconnected the vacuum line on the FPR.
Another odd thing is at idle it does not seem to care if I take the oil cap off or remove the dip stick. I seem to remember that either of these would normaly cause major vacuum issues.
I have checked the Oxy sensor and all readings are in spec but they are really low at idle and if I let it sit it wants to drop below the 0.020 minimum. As soon as I give it gas the oxy pics up but it idles at the bottom of its indicated range. The oxy heater is working and all is well with that part. Still getting 1222. Also I should note that the car runs great it just idles poorly and signals code.
Input apprecaited.
Input apprecaited.
