um...is my headgasket no good?
  • El Gato Liso
    • Jun 2008
    • 44
    hi all
    i did my m50 swap over a year ago, but now i think my engine took a shit. well, it goes like this...
    i turn on the engine. and exhaust is burning mad white smoke on a cold start. eventually when hot, white smoke either goes away or just lingers.
    maybe after a good 30-60mins of idling with no r3ving, the coolant expansion chamber goes BOOM and coolant shoots out...as if 1 giant air bubble forms out of no where.
    and before its mentioned, yes, i bled the system properly, with the heat on maX.
    any suggestions.?
    thanks !
  • StereoInstaller1
    GAS
    • 22679
    Suggestion? Buy a compression tester and use it. Should be under $20, read the instructions and do it properly, that will tell you enough to know if it is toast.
    Closing SOON!
    Thanks for 10 years of fun!
    • 328ijunkie
      • May 2007
      • 3961
      "30-60mins of idling"
      Does the car overheat while its idling for an hour?!
      Check Us out on Facebook
      Full Product Line Tuning
      • Mr.SWISS
        • Nov 2005
        • 1251
        I would re torqe the bolts to 75lbs before I yanked it in case one backed out and allowed it to gap. Run a few heat cycles and see if it subsides, if not a decking and fresh gasket will be in order.
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • El Gato Liso
          • Jun 2008
          • 44
          well compression test resulted about 210psi per cylinder, with like 2 adjacent cylinders reading about 195 or just below 200psi
          i dont get this m50....dont get it at all, but its burning coolant. what a head ache...
          • StereoInstaller1
            GAS
            • 22679
            So if your compression is that high, you may have a cracked head, a cracked block or a broken water pump.
            Closing SOON!
            • e30rapidic
              • 2167
              like they said above, you need to start with the cheap stuff. Check torque specs on the head bolts first. If they are ok, then have a cooling system pressure test done. Hopefully its the gasket and not a crack....
              '87 325ic, powered by S50.
              • DesertBMW
                • Aug 2011
                • 1042
                Very common, small crack at the head resulting in combustion pressure leaking into cooling system.
                http://e34touring.blogspot.com/
