Not Cranking / No Power to Starter
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Was helping MrTwo last night with replacing his clutch (S52 w/ Getrag 260) and now his car will not start. I will mention that during the start bolt removal process he arc'd the starter because he forgot to disconnect the battery. Its a brand new aftermarket starter.
    Now it doesn't even turn over. Power turns on and everything seems to be getting power except when he goes to turn it over nothing happens. No noise, no click, no nothing.
    Checked every fuse and they are all good. Double checked the wiring and it was good too. Replaced both unloader relays for good measure. Still nothing.
    Is there somethere that could have been severely damaged when the starter was arc'd or are we overlooking something? Maybe killed the starter?
  • dirty30
    • 3014
    Did you try jumpering/ hotwiring the starter?
    • I*Do*Werke
      • Dec 2010
      • 259
      do all the dash lights come on in position 2?
      If not, then you have an engine ground problem. It is VERY common for engine swaps with older engines to have a ground problem. Even though the contact is there, corrosion can impede the ground so make sure all the connections are clean
      ^M52B28^
      • etxxz
        • Feb 2006
        • 2085
        chances are the starter is okay and you missed a wire(s).. bet you don't even hit the starter click - go back get err done ; |
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
        • RobertK
          • Jun 2005
          • 5864
          Honestly never jumped a starter before manually. What the best way to do this with the starter bolted up in the car?
          We double checked the starter wiring a dozen times. IIRC.. power from battery and alt to the 13mm, one small wire to the 8mm and one small wire to the 10mm?
          We never messed with the engine gound but its worth a look. Hopefull this rain moves out so we can get to it again.
          • Jafxod
            • May 2011
            • 1301
            Pull back the black covering on all your wires and make sure your reds are connected to the + and the brown ones are hitting ground.
            • e30rapidic
              • 2167
              bang (no, make that a hard tap, tap a few times) the starter with a hammer and then try again see if it does anything. Seriously!
              '87 325ic, powered by S50.
              • e30shmobberr
                • 1934
                same problem i cant get my s50 to seem to crank. nothing when i turn the key
                Patrick - IG:niicknac
                RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                • MattM
                  • Apr 2009
                  • 931
                  did you mix up the 2 small wires?
                  Full Build Thread Here
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    they are different sizes.
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
                    • RobertK
                      • Jun 2005
                      • 5864
                      Replaced the starter with a good used one and it cranked right up.
                      The original starter was a cheap rebuilt from O'Reily's. The ground strap was very loose.
