Hello,
Have a question about a wire.
On the left hand side of the engine bay harness are two power wires that end near the blue fuse box. This is well known. I know I can eliminate the big red one, as it is for fuse box power and the E30 fuse box gets its power from elsewhere but what about the SMALL red wire??
I can trace it back to one of the three relays on the wire harness. It's a large enough diameter that its a power feed (well plus the color tells us that too)
Anyone have a good tip for this wire?
Second question: Grounds.
The standard harness has an awful lot of excess grounding wire in it. When you unpick the harness you see earthing wire looped endlessly around the place, with quite a lot of random earting points.
Given my reasonable levels of electrical understanding, a ground should be the shortest point to chassis, preferably in as few spots as practicable. So is it reasonable to shorten the length of a lot of these earth runs?
thanks a bunch
burkey
thanks a bunch
burkey
