Slow cranking starter, lots of sparks
    Finishing up my swap, I'm using an E36 starter, wiring harness, and flywheel. starter meshes and the motor turns over, but its VERYYYYYY slow and lots of fucking sparks fly out. What the hell's going on?
    Originally posted by TSI
    OEM+
    Sparks are flying out of where?
    Check Us out on Facebook
    Full Product Line Tuning
      You have a bad ground, check the ground on the engine arm to the chassis, if bad, add another ground.
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
        Sparks are flying from the starter area. I'll add another ground from the drivers side motor arm to the chassis and see what happens
        OEM+
          bump for more input?
          OEM+
            Tighten the 12v cable connection at the starter.
            m
              It doesn't seem like it's coming from that wire though, but almost in front of the starter.........lols?
              OEM+
                comeon dudez
                OEM+
                  If you have no blown fuses, Make sure that any large 12v unswitched cable is not pinched.
                  Make sure that the wires for T30h and T50 are not being pinched.
                  Make sure that the connector lugs for the starter and alternator cable are not grounding out on the starter arse in the vicinity of T30.
                  It's up to you to pin point exactly where the sparks are coming from.
                  If it is definitely coming from the nose of the starter/bell housing, you're going to have to make sure that you're using a matching starter/flywheel combo.
                  m
                    I got it, turns out the extra power positive wire from the e36 harness was touching in front of the starter (grounding it out) and I simply did'nt have enough battery even though it was being attached to a charger on "engine start" haha.
                    OEM+
