I have e46 6 speed and euro e36 6 speed trans mounts available. All you need is your choice of bushings. Made out of 6061 Aluminum. PM me for pictures and price.
can you post a photo of how this installs?
does this brace the body more than standard mount? how is the NVH?
do nut serts need to be installed in the chassis for the added 2 mounting points??OBD1 M54/M52TU swap as a M50b25
Originally posted by Wanganstyle View Postcan you post a photo of how this installs?
Both my E30's had 4 bolts/studs there, you can slide them down the tunnel and adjust however you like.
Why not use an e36 auto trans brace with elongated holes?Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.
Mounts to the standard 4 trans tunnel bolts and then bushings wether stock, solid, or poly bolt to this and then to the 6 speed. I have a tunnel cut out of a car that I made this off of, but I can ask someone that has one of these bolted in to take some pictures. I dont even know what a stock mount looks like to be honest but the vibration of it is going to depend on what you chose for the bushings/mounts.
Nice idea. When I did our 6-speed mounts for the shop, I made an adapter plate that bolts onto the back of the trans and uses the stock E30 mount.
Many roads to rome.
Nice fabbing.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
That looks great.. I didn't even know you guys were doing them in aluminum. Mine should be here any day now, can't wait-- it's the last part of the puzzle. Although now I've been thinking about having you guys mod a subframe and oil pan so I can use the E34 pan on something else. It just sits too low for my daily use.
Thanks for cranking out the great products!
