Hi everyone..
I'm at work so no pictures but today I twisted my shifter carrier and selector rod 10 degrees to the left(if your sitting inside the car, this would mean towards the driver) and 1st gear is where 3rd gear should be and reverse is where 1st should be:(. Neutral isn't even in the middle, and 2nd and 4th are located where neutral use to be. Transmission seems to go in every gear, not smoothly tho.. Did I do something wrong? Anyone point me to the rite direction to lining the shifter up in the middle. It seems that even if I turn it another 5 degrees the shifter it self sits to far forward
. Does anyone sell the shift linkage already pre-bent? Sorry if this should have went in the Transmission section, So I have S52+G260/ stock shift linkage 10 degrees to the left. Thanks in advance:), and oh yea if anyone wants to share they pictures id appreciate that as well.
