Radiator and cooling
    Hey guys, so I have a little under 2" of clearance between my fan and where my rad is supposed to go. Do I take the fan off and run electric? Or can I use the fan off my m10? WATDO?!
    1984 318i (w/ delicious M50 powa)
    Produktionsdatum: 03.10.1983
    Außenfarbe: Achatgruen Metallic (177)
    Running an electric puller fan seems like the better option. Purely in the sense that you have less drag on the motor.
      Wrong mech fan.
        So which mechanical fan should I be running?
          There is lots of fan info if you search. You might want to look into the 'euro diesel clutch fan'
