M50 crankshaft bearing specs question.
  • lolcantturn
    • 4588
    Hay guys. As my M50 was an E36 motor, i pulled the E36 oil pan baffle that was bolted onto the bearing bolts. Untorqued those bolts with an impact gun and put them back in, not torqued to spec with an impact gun. it's looser than what it would be torqued to spec. totally didn't phase me that it needed to be torqued really specifically, but i put the pan back on, put motor in the car, and drove the car about 4 blocks and then it was back on jackstands (had to do more work to it). Basically, is my engine a ticking time bomb now? Not looking forward to pulling it again to fix this.
    Originally posted by TSI
    OEM+
  • Gnarles
    • Dec 2008
    • 342
    are you talking about the oil pickup bracket because the e36 windage tray is not attached to the bearing caps. If you are talking about the oil pickup bracket, if it were me, I would pull the oil pan back off and fix it. I believe those bolts are torque to yield (torque value + angle), so you should get new ones.
    • lolcantturn
      • 4588
      Oh geeezeeeeee, anymore input before i pull the motor?
      OEM+
      • scottinAZ
        • Dec 2009
        • 1312
        +1
        Pull the pan, replace the main bolts. its only the entire engine that can grenade if you dont.
        for the record, I broke my pickup support off so I didnt have to disturb the main caps. not something you want to fuck around with
        I saved 15% on my Bimmer parts by switching to ...
        • 328ijunkie
          • May 2007
          • 3961
          They're TTY bolts and can't be reused.
          Check Us out on Facebook
          Full Product Line Tuning
          • lolcantturn
            • 4588
            cant find..place to..buy...two crankshaft bolts...anywhere?
            OEM+
            • lolcantturn
              • 4588
              I can't even find it on realOEM.
              OEM+
              • MattM
                • Apr 2009
                • 931
                11111735525 ?
                Full Build Thread Here
                • lolcantturn
                  • 4588
                  well this is gonna suck
                  OEM+
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    woodscrews work
                    Originally posted by Wh33lhop
                    VANOS: sometimes you just need to go full retard.
                    • DesertBMW
                      • Aug 2011
                      • 1037
                      Originally posted by lolcantturn
                      Untorqued those bolts with an impact gun and put them back in, not torqued to spec with an impact gun..
                      If you used big 1/2" drive impact gun to torq the main bearing bolt back you will be OK. These impact gun have maximum torq from 70lb to 150lb so you will be safe.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Please don't ever post such terribly wrong information ever again. Kthx
                        • lbreevesii
                          • Aug 2009
                          • 412
                          seriously.
                          <3.00 for the bolts. just do et.
                          I don't always wreck cars, but when I do I wreck them into trees.
                          91' 318is S50 swap - The Black Widow
                          • scottinAZ
                            • Dec 2009
                            • 1312
                            +1
                            I know my impact goes up to 450 ft/lb in forward and 600 in reverse. definitely more than the torque on a main cap, and enough to remove any nut its come across
                            • jrdeamicis
                              • Nov 2008
                              • 956
                              Sucks, but you have to do it. Make sure you clean the threads on the block before you put the new bolt in. (Preferably with a bottom tap). Then oil the bolt. Then retorque.
                              Past Car : E30 S50 6 Speed 5 Lug 3.73
                              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                              ___________________________________________
                              BNB Designs
                              Engine Swaps, Fabrication, Innovation, General Repair
                              Richmond CA
                              Julian 848-248-8029
