735 master cyl, front brakes not bleeding
  • blueapplesoda
    • Dec 2005
    • 1904
    I'm tidying up the last little bits on the m50 swap car, and I ran into a bit of a problem. As I try to bleed the front brakes, barely anything comes out. I am using a bav auto pressure bleeder which has worked for years on many cars and never had a problem. The rear bled fine.
    The brake pedal is almost solid when I try to push down on it, which makes me believe maybe the lines got mixed up somehow. I followed the same pattern (as to what lines went to what port on the master) as the e30 master...I didn't think it would be any different, unless I have to switch something...
    Thoughts?
  • jahnaboi
    • Oct 2006
    • 1742
    To hard to contact me huh? lol
    You're problem is the master-cylinder. If I remember correctly I had the same issue once before and it was because the master cylinder has a metal insert where the boots for the reservoir go. I believe when I had my remote setup on (using the 2002 remote setup) the metal insert (thin flap of metal) was blocking/restricting flow. Either that, or the tandem m/c is bad.
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • samiam3356
      • Jul 2009
      • 1901
      Did you remove the ABS?
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
        • 37829
        Did you bleed it at the master first?
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • e30rapidic
          • 2167
          Were the brakes working fine before you swapped the M50 in? How long ago? Are you doing this with the engine running?
          Crack open the front bleeders and push the pedal, does anything happen? Even if the car is running? If there is water in the lines, the pedal can be really stiff. Also a frozen caliper or a foreign object in the line. A bad booster or no vacuum could make the pedal stiff too
          Did you bench bleed the master before putting it together? Cycled the ABS to get air out?
          '87 325ic, powered by S50.
          • e30s50dan
            • Nov 2008
            • 2076
            is it a NEW master cylinder...if its used,may be trash!
            you shouldnt have to bench bleed it..Ive been pressure bleeding many cars,and not once had to bench bleed!....its not a 71' dodge
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
              • 37829
              For the record I've bleed the brakes on probably 100 cars. Not one have I ever used a pressure bleeder on.
              Grover Beach, CA
              www.BimmerHeads.com
              • e30rapidic
                • 2167
                ditto. and never on a '71 Dodge
